Michaels Web Site
Date:  12-4-2011
Number of Hours:  2.25
Manual Reference:  F06
Brief Description:  Glare shield & panel
Spent some time looking over the F06 drawing sheet. Went to a couple of other Sonex web sites to see in what order others had done this sheet.
- Test fit the glare shield in place (photo #1).
- SAT IN THE THING FOR THE FIRST TIME! Momentous occassion!
Started building my panel. I don't have any instruments yet, but I have the layout to scale. Per photo #2 I plan to make the two ends fixed (riveted) in place, and have the center section held in place top-and-bottom with hinges (like the seat and cowl), and the vertical edges with some nut plates and screws.
- So I started building the removeable center section, which you can see in photo #3. The partial hinge half at the bottom is just for reference.
Glare shield test fit into place
Panel plan: two ends are fixed; center section is removeable
Look at photo #2, then this one, and you can recognize the removeable center panel
