Michaels Web Site
Date: 10-9-2011
Number of Hours: 3.75
Manual Reference: F11
Brief Description: Fwd fuselage side panels + bottom skin
- First I disassembled the right hand side panel installed last night, so I could then turn the fuselage around on my work bench. The bench has my bending brake on it, which I will need again soon, so I needed to rotate the fuselage to work on the left side skin, opposite from the brake.
- I installed and pilot drilled for the left panel, just as I did for the right panel, yesterday.
- The I needed to install the forward fuselage bottom skin. Since I took the fuselage off the sawhorses and placed on the workbench I needed to elevate the fuselage so I could get to the underside. I did so by placing two 2x4's under the rear fuselage, and letting one side of the bottom skin overhang the workbench (photo #1).
- I clamped the front of the skin in alignment with the lower motor mount bracket per the plans (photo #2). Then I aligned on edge of the skin and began pilot drilling and cleco'ing (photo #1).
- Then I moved to the other side. But the brake was in the way so I simply propped the 2x4's under the fuselage, on top of the bending brake angles and let it hang out far enough to do the work (photo #3).
- Holding up the bottom skin so it was not sagging I pilot drilled the holes in the other longeron.
More on the next page...
Aft fuselage elevated so forward fuselage bottom skin can be applied.
Front edges of bottom skin aligned and clamped, awaiting drilling.
With bending brake in the way, simply elevated one side to get to pilot holes in bottom skin.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
