Michaels Web Site
Date: 8-8-2011
Number of Hours: 2.75
Brief Description: F24-01 Cross Tie Box Ass'y
Made the F24-01 Cross Tie Box Assembly for the fuselage.
- Draw 5/32" offset line on legs of channels, per plans - Clamp channel to work bench, standing up - Clamp 2nd channel, 3" off of the first - Align one face of cap strip along offset line of ONE channel - Pilot drill and cleco in place
- Measure 3" wide at one end of the assembly, clamp, pilot drill and cleco one end hole. - Move down the assembly with a ruler and measure a 3" wide assembly. - Assume channel may not be perfectly straight and move down assembly, measuring 3" pilot drilling and cleco'ing as you go, until you reach the other end of the assembly - Disassemble and debur
- I put in 6 clecos, turned the assembly over, LIGHTLY clamped it to the work bench, then did the same thing as above, for the other cap strip.
NOTE: PER THE DRAWINGS ONLY ONE CAP STRIP (the one with fewer holes) GETS RIVETED AT THIS TIME!
- Riveted one cap strip in place. More photos on the next page.
2 channels clamped to work bench at near end. Cap strip clamped on top.
Overall view from opposite end.
Align cap strip with offset line on channel. Pilot drill, cleco, measure 3" to the other face.
Copyright © 2001-2020 Matronics. All Rights Reserved. |
