Michaels Web Site
Sonex Standard Gear
LEFT flap construction
- Laid out the angled cuts at the inboard/root end of the flap skin
- Made the cuts at the angles with the Dremel cut-off wheel
- Made the rest of the cuts with the shears
- Laid out and drilled all the pilot holes in the skin, for the rib attachment
- Marked all the rib flanges with a centerline
- Drilled and cleco'd one face of all the ribs (photos 1 & 2)
Outboard end
Inboard end
Typical pilot holes in skin
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
