Michaels Web Site
Sonex Standard Gear
RIGHT flap construction
- Laid out the locations of the cuts at the inboard end (photo #2).
- Laid out the centerline of the rib locations on the skin.
Testing where the inboard rib will go.
Marking up the flap for the cuts that will allow the flap to follow the fuselage angle.
Testing where the outboard rib will go.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
