Michaels Web Site
Sonex Standard Gear
LEFT horiz tail tip installation
- Bent the ribs. Curved ones on the bending block; straight ones on the small bending brake
- Test fit the ribs in the fiberglass tip, and then against the horizontal tail. Looks good. It will need some tweaks.
Bending block
New tip ribs
Test fitting the ribs and fiberglass tip
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
