Michaels Web Site
Sonex Standard Gear
LEFT aileron construction
- Got the last rib located and pilot drilled, then updrilled all the holes.
- Pre-drilled small pilot holes in the hinge, set the hinge as I did for the right aileron, then
- Started drilling the hinge into the aileron. Got a half dozen holes set.
Sonex Standard Gear Home
Aluminum Materials
Angle Parts
Bending Brake
Cowl
Finish-Polish
Hardware
Learning Point
Smoke System
