Michaels Web Site
Sonex Standard Gear
RIGHT wing preparations for riveting
Started back up on the RIGHT wing.
- Deburred the holes on an aft skin along the rear spar
- Enlarged the hole in the lower aft wing skin, and set the tie-down bolt in place and torqued the nut.
- Installed nut plates for the installation of the pitot assembly.
Reached 1,100 hours tonight.
Tie-down bolt in place.
Pitot assembly ready for mounting.
Nut plates in place for the pitot assembly.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
