Michaels Web Site
Sonex Standard Gear
RIGHT wing - deburring
Finally got everything deburred. Then I located (lower aft wing skin) and drilled for the wing tie-down bolt.
Started puting the wing back together with clecos so I can install the fiberglass wing tips when they arrive, and then finally start riveting.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
