Michaels Web Site
Sonex Standard Gear
Vertical tail tip
A final picture of the fiberglass tip test fit in place over the entire assembly. Next will be to reinstall the rudder to test the fit at the fiberglass tip, to determine if anything needs to be cut. Then I'll be able to drill for screws or rivets.
Fiberglass tip test fit in place.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
