Michaels Web Site
Sonex Standard Gear
RIGHT wing deburring + nose skin
Not much work over the past week. Was on vacation for half of last week, then got sick after returning. Just got back to work today.
- Finished deburring/sanding holes in ribs and lower aft skin
- Used one leading edge (nose) wing skin as a pattern to lay out the second
- Cut out that second skin
- Also went back to the LEFT wing and installed a third wire for the future wing tip lights, and set the 25 deg angle of the aileron bellcrank.
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
