Michaels Web Site
Sonex Standard Gear
Elevator hinges
OK, I guess I wasn't quite done with T07. I needed to drill the holes in the hinge halves to be truly done.
So tonight I aligned the elevator assembly with the horizontal stab and marked the elevators for the hinge locations.
Then I marked the hing hole locations and drilled on the drill press. Deburred, then cleaned the layout marks off the hinges.
Marking elevator hing halves for drilling
Sonex Standard Gear Home
Aluminum Materials
Angle Parts
Bending Brake
Cowl
Finish-Polish
Hardware
Learning Point
Smoke System
