Michaels Web Site
Sonex Standard Gear
Elevator hinges
OK, I guess I wasn't quite done with T07. I needed to drill the holes in the hinge halves to be truly done.
So tonight I aligned the elevator assembly with the horizontal stab and marked the elevators for the hinge locations.
Then I marked the hing hole locations and drilled on the drill press. Deburred, then cleaned the layout marks off the hinges.
Marking elevator hing halves for drilling
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
