Michaels Web Site
Sonex Standard Gear
Bent then cut 2nd elevator skin
- Bent the 2nd elevator skin
- With the skin taped closed, I measured and cut the angled inside edges of the skin.
- I took the tape off to open the skin, then with snips I cut just outside the lines I drew on the metal, then finished with files & sandpaper
After bending the 2nd elevator skin
Then cut the inside edge of the elevator skin per the plans
I cut just outside the lines on the metal, with snips, then finished with files & sandpaper
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
