Michaels Web Site
Date:  4-14-2010
Number of Hours:  2.50
Brief Description:  Wing attach assemblies
- Made the second angle W11-05. I thought I had made it, but apparently made only the first one. Took about a half hour of so to make.
- Used the W11-05 angles and two of the attach blocks to make the W11-02 wing attach assemblies. I already had the holes drilled in the blocks, so I clamped the to the angles with the required spacer, and used those holes as guides to drill through the angles. I'm not worried about making the 3/16" holes in the blocks larger by doing it this way, since those holes will be enlarged for tight-fit bolts later.
I don't have the required bolts on hand, so the ones in the photos are temporary from the local hardware store.
Spent another 1/2 hour making the parts list for the hardware I need for the assemblies on sheets W11 and W21.
Drilling thru the blocks to the angle
The setup of the clamps allowed the angle to lie flat and square
The finished W11-02 assemblies (with temporary bolts)
