Michaels Web Site
RV-7
7 Wing
1-31-2024
Continue right wing tip
Started by cutting off the trailing edge of the wing tip, aligned with the trailing edge of the aileron.
Then updrilled all the holes to #30, and used upsidedown nutplates to drill the #40 holes for the nutplate rivets.
Started countersinking the fiberglass at all the screw and rivet holes at the nutplates.
Cut the trailing edge to match the aileron
Updrilled to #30 holes, then drilled for all the nutplates
Upsized center holes to #19, then countersunk for rivets in nutplates
RV-7 Home
697
7 Electrical
7 Empenage
140
195
7 Finish Kit
7 General
7 Tools
7 Wing
300
494
7-Misc Parts
Sonex Standard Gear Home
