Brief Description: Aileron attachment and rigging (1 of 2)
Had a power outage last night, so no work.
Tonight, started attaching the ailerons so they can be aligned/rigged.
There is an alignment plate/jig that gets put on the aileron bellcrank. Then the aileron is attached, and aligned with the wing skin. Then the rod end bearings are screwed in/out to get the aileron pushrod in the right place.
