Michaels Web Site
RV-7
7 Empenage
10-6-2022
Tools for empenage hinges 2 of 2
The thin tool is easy to get through the holes, and gives you initial alignment.
While holding the control surface steady, replace the thin wire tool with the 3/16" tool.
Now you can work the bolt in from the side OPPOSITE the tool, essentially pushing the tool out, as the bolt gets pushed in.
The best way I found to get the bolt in there was to use Gorilla Tape to hold the bolt head in the box end of a 3/8' wrench.
The 3/16" tool goes through, and gives final alignment.
DId the same for the rudder.
RV-7 Home
701
7 Electrical
7 Empenage
140
195
7 Finish Kit
7 General
7 Tools
7 Wing
303
498
7-Misc Parts
Sonex Standard Gear Home
