Brief Description: RIGHT elevator ribs & counterweigh
Recieved the replacement parts for the ones I messed up. Orderd on Sunday, received on Thursday. Not bad!
My band saw needs a replacement part, so I did not cut out the large section from the counterweight. I'll do that later.
Put the parts together, and this time drilled with the #12 bit right off; no pilot hole. Worked MUCH better! You still want to spin the drill very slowly, use lubricant, and clean the lead out of the drill bit often.
Pictures here are before drilling. Next page has the drilled holes.
