Michaels Web Site
Date:  2-12-2024
Number of Hours:  1.75
Brief Description:  Finished left wing tip, start light lens
Prime painted the tip rib. Counter sunk the rivet holes in the fiberglass. Riveted the rib in place.
Then worked on the lens for the lights. LOTS of trial and error, but a bit faster than the first one since I knew what the end result should be. All the cutting is done. I just need to final sand the edges, and then I can do the nutplates to for the screws to hold it in place.
Primed inside and flanges of rib
Got the lens cut to size. Just needs sanding.
