Michaels Web Site
RV-7
Finish nutplates for left tip
Finished installing the nutplates on the lower tip skin.
Then cut off and sanded the trailing edge (to align with the trailing edge of the aileron).
Sanded the interior cut lines on the traiing edge.
Then set the trailing edge rib in the wing tip, and drilled for the rivet holes.
Finished nutplates and sanded the trailing edge skin cuts
Cutting the trailing edge to match the aileron, yields this
Aligned, and then drilled for the trailing edge rib
RV-7 Home
696
7 Electrical
7 Empenage
140
195
7 General
7 Tools
7 Wing
299
493
7-Misc Parts
Sonex Standard Gear Home
