Michaels Web Site
RV-7
Start right wing tip (2 of 2)
Next, I used a Sharpie to make the impression in the foam, more visible. Then I used the band saw to cut out the shape.
Used some coarse sandpaper and a finer sanding block to tweak the edges of the foam.
In photo #2 you can see how the foam holds open the fiberglass.
I then made the initial rough cuts of the back edge of the wing tip.
Make the impression more readable with a Sharpie
After cutting and sanding, the foam holds open the open end of the fiberglass tip
First rough cuts for the aileron clearance
RV-7 Home
697
7 Electrical
7 Empenage
140
195
7 Finish Kit
7 General
7 Tools
7 Wing
300
494
7-Misc Parts
Sonex Standard Gear Home
