Brief Description: Start right bottom outboard skin
Time to start installing the last wing skins!
I wanted to prime paint the narrow section of the inboard skin, where the outboard skin will overlap it. I put the outer skin on, then taped along the edge (1st photo). Then I removed the outer skin.
Then I used newspaper to cover the rest of the wing so the primer would not get on the rest of the exposed skins (I forgot to take a photo).
Prime pained (photo 2).
Before I did that, I match drilled and dimpled the wing skin along the back edge (photo 3).
Tape off edge of overlap
Remove skin & prime paint overlap
Dimpled the back edge of the skin, where it meets the flap brace
