Cut the tubing coming from the pitot/static. The kit comes with straight fittings, but I opted for 90 deg fittings so I would not have to bend the tubing 90 deg. The last photo is how the pitot and plumbing will sit in the wing. The plastic tubing will run from the fittings,through the two padded clamps, and then through grommets down the length of the wing.
Flared pitot/AOA tubing
I opted to buy 90 deg fitting instead of bending the tubing
