Made a plate to attach the pitot heatin module to, and then created and riveted back plates with nutplates onto the wing rib.If the module ever needs to be removed I remove the 4 screws into the nut plates. If the size of the module or the holes in the module change on a future model, I can drill new holes in the same plate and reinstall to the same nutplates.
