Michaels Web Site
RV-7
AP wiring at right wing
I wanted to have disconnects in case I ever had to replace the Auto Pilot servo, so I installed those tonight.
There are 7 wires, so I used 4-wire connectors. I'm waiting for the White/Green and White/Blue wire I ordered, then I can finish.
The loose ends of the wires will get run inside the black conduit. I have 3 pull strings running through each.
In case I ever have to replace the AP servo, I installed disconnects.
Power, ground & AP disconnect
All wire ends labeled inside shrink tubing
RV-7 Home
697
7 Electrical
7 Empenage
140
195
7 Finish Kit
7 General
7 Tools
7 Wing
300
494
7-Misc Parts
Sonex Standard Gear Home
