Michaels Web Site
Date: 10-22-2023
Number of Hours: 0.75
Brief Description: LEFT wing aileron pushrod + stall warn wire
Dinally got the AN3-21A bolt I needed this weekend, so attached the aileron pushrod to the bellcrank.
Also ran the stall warning electrical wire, through a rib, back out the rib, and into the plastic wiring conduit. I used a soldering iron tip to put a hole in the conduit, to run the wie. Note that I ran the wire UNDER the bellcrank and the pitot support bracket I installed earlier, thru a rib, then back through the same rib before running the wire into the conduit. The reason for returning that last time through the rib, is that the wire will be easily accessible from the access panel that is there, if the wire ever needs to be pulled out.
Pushrods done, and stall warning wiring run
