Michaels Web Site
Date:  6-24-2023
Number of Hours:  1.25
Brief Description:  RIGHT aileron spar work
The spar ends are another place where the instructions suck, and the drawings are not nearly as clear as they should be. In a nutshell:
- Align the -408 reinforcing plate with the outside edge of the spar.
- Clamp it to the work table and drill through the spar holes to create the holes in the reinforcing plate. Cleco as you go so it does not move.
- Debur.
- Machine countersink the front face of the -408 plate, for the (2) rib rivets, and the (2) nutplate rivets.
- Cleco the plate in place on the spar, and cleco the end rib in place.
- Drill the #12 holes at the top and bottom of the rib, and the one offset from those two, in the center.
- Disassemble and debur.
- The instructions say to cleco the white painted brackets in place, but you can't!
- So I just drilled the bracket with the #12 bit. It still aligned with the holes in the spar and rib.
- Debur everything.
- Prime paint if you are inclined (I did).
- Set the nut plate with the 3-4 flush rivets.
- Set the rib with the 3-4 flush rivets.
Nut plate from the back side.
I did some touch-up priming, so you may nots see the flush rivets well.
Flush rivet (tails) on the back side of the rib.
