Brief Description: Seal rear baffle LEFT wing tank
Installed and sealed the rear baffle of the LEFT tank. I took some lessons from the first tank, so I think this one was done better.
One thing I learned is you should put the end Z-brackets on now, not later. There's sealant between the baffle and the rib, there, so it's best to put those 2 brackets on now.
Not great photos. I took them after I flipped the tank to let gravity work on the sealant.
