Brief Description: Right tank access plate hardware
I installed all the parts and pieces on the access plate for the right wing. It seemed like it would all be easier to do outside of the tank, so that the only thing left was to put sealant on the rib opening, and screw the plate in place. It was very easy to work on everything in a vice.
I tested the fuel sender for continuity (between the center screw of the sender, and the plate). All checked out.
