Dimpled all the access panel parts and the wing skin holes. Note that you do NOT need to use the supplied template to locate the holes for the stall warning slot and rivet attachment. They are already there (see photo #3, below). The template is if you are retrofitting, or if you were building an older kit.
Installed the nut plates.
Back riveted the reinforcing plate to the wing skin.
Not shown: cut the slot between the #10 holes in the leading edge, for the vane to protrude.
Nut plates installed
Back riveting is the best way to install the reinforcing plate
The kit already has the correct holes. Not need to use the template.
