It's taking me about an hour to install each rib. So I only mix enough sealant for 1 rib at a time. 35 grams of the white stuff seems to be a good amount to use for each rib. You'll still have some leftovers.
Using slotted wood to hold the skins apart while lowering the rib into place.
