Brief Description: RIGHT Tank Install fuel filler & drain fitting (1
I decided to install the fuel filler and drain fitting for the RIGHT tank today, since I just did it for the left. This time I decided to put painter's tape around the work areas to try to make cleanup easier. For the 15 minutes it took to install all the tape, I think it did help with cleanup.
