Michaels Web Site
Date: 4-14-2023
Number of Hours: 1.25
Brief Description: LEFT fuel sender float
I used pieces of metal coat hangars to test the bends needed for the float to read full and empty. It took a lot of trial and error, but I finally came up with something I was happy with.
So I transferred the bends to the wire arm of the float, and made the bends. The float arm is MUCH stiffer steel than the coat hangers, and the coat hangers are a little thinner. When I went to put the 90 deg bend into the sender body, I found the bend radius was too large to fit! The plastic body of the moving arm requires a nearly 90 degree bend, something the instructions never point out.
I tried hammering the wire over an anvil to try to get a 90 deg bend, but nothing worked. I've ordered a new float arm so I can try again, but I need to reach out for help/ideas on this. I could use my welding torch and heat it to bend it 90 deg around a steel edge, but I'm afraid I'll accidentally cut through it, or that the heat transfer will reach to, and melt, the float.
Multiple iterations with sections of coat hanger
The final coat hanger bends
Radius too large! Wire won't seat.
