Brief Description: LEFT wing ribs + fuel tank (2 of 2)
For the fuel tank, the instructions say to put the skin in the cradle first, then cleco in the ribs. But that makes it horribly difficult to get the clecos into the forward holes in the nose of the ribs. It works much better if you start by cleco'ing the most forward hole of the skin and rib, like in the first 2 photos below.
Then you slide the assembly into the cradle, and the rest of the clecos go in super easy.
One cleco in the forward most hole in the nose rib
Like this...
After that, you can put the whole thing into the cradle to do the rest of the clecos
