Lots of extra things to do on the LEFT wing, due to the pitot/static system & stall warning.
I still had the fly cutter set up from cutting out the access hole in the right wing root tank rib, so I went ahead and cut out the access panel for the left one.
I am going to use Dynon products, including a heated pitot. I need to run the tubing and wires, and not interfere with the aileron bellcrank. I found this web site that had good ideas for brackets, so I made my own.
