Riveted the left skin along the forward spar and the after center rib. Using the rivet tape I put all the rivets in place, then could just do one after another in fairly short order.
Used a wide, flat bucking bar. Leaving the horiz stab horizontal on the table allowed the easiest access, and was pretty simple to get good rivet sets. I didn't have to drill any out.
Rivet tape makes the process much faster.
I'll have to touch up the primer, from the bucking bar.
