Riveted together the center bearing bracket and bearings.
Upsized the holes for the 4 bolts that hold the brackets in place. Make sure you go SLOW when drilling through the steel brackets, and step up in drill sizes until you get to the final #12 bit. Bits this large will grab and wreck parts if you don't go REALLY, REALLY SLOW!!
Finished cutting and finishing the shaped ends of the spar reinforcing angles.
Deburred any of the holes I drilled recently or tonight.
Stepping up the drill bits for the bearing brackets
