Here's one of those instructions that drives you nuts for a while.
The instructions say cut the flanges at an angle, but gives no dimensions. It only notes to maintain the minimum edge distance to the hole in the flange. The problem is, there IS NO HOLE IN THE FLANGE at this point. The flange will not get a hole there until the skin is overlayed for match drilling.
They should say to leave this alone until the match drilling is done, later. But it takes a lot of head scratching to figure that out. Section F-F should simply say to cut the angle later, after the flange holes are drilled. That would have saved me 20 minutes of wringing my hands trying to make sure I didn't screw something up.
Can't do this until the skin is overlayed to locate the flange holes.
How do you maintain edge distance without a hole there?
You don't get holes in the flanges until the skin gets match drilled.
