Used the rivet squeezer to dimple the holes in the stiffeners.
Used the C-Frame to dimple most of the holes in the RIGHT skin, but the ones closest to the folded trailing edge needed the "Simple Dimple Die," which uses a rivet puller to squeeze the dimples.
"Simple Dimple Die" required close to the trailing edge
