Match drilled a 48" aluminum angle that will hold the trailing edge straight.
Started installing the last rib and riveting the skins.
The last 2 holes at the top (rear) are too tight to get in even a thin bucking plate, so pop rivets are used. No big deal; my entire Sonex was pop (blind) rivets! Although these are aluminum, and the Sonex uses stainless steel.
