Brief Description: Finally back to building after some time off
Back to building the rudder after some time off. Fabricated the R-717 spacer, and both R-716 rudder bottom attach strips from the spare stock that comes with the kit. Built the sheetmetal brake so that I could get the rudder skin bent to the correct angle which gives it a better/closer fit to the skeleton.
Fabricated the R-717 spacer, and both R-716 rudder bottom attach strips.
