Brief Description: Finished deburring right HS, and structure.
Finally got back to work on the HS after a couple of weeks of not being able to do anything with it. Life gets in the way...Made some decent progress, finished deburring the right HS, and sub-structure. Will look into cleaning and possibly priming this week.
Right Hs deburred and dimpled.
About to prime the through holes in the rear spar brackets.
Holes primed with self etching primer...I used a Q-tip for this.
