Brief Description: Continuation of work on rear spar assembly
Made some decent progress tonight. Got nearly half way through the rear spar assembly part of the build instructions. It's good to see parts go together. So far, no issues with anything except for the HS-609PP's had some deep scratches in the wide faces which required quite a bit of scotchbrite wheel time. In the end they came out, and the parts look nice and smooth.
Using a coarse vixen file to round the edge of HS-609-PP
