N444MG
Date:  7-20-2019
Number of Hours:  130.00
Brief Description:  Tooling Complete (for now)
Tooling included making the garage a workable place. This involved extending the house AC to the garage and adding a dampner/switch to cool the area. Cool, huh?
In add, I had to add insulation and a fan in the attic to vent the hot air out the side soffett vents. I figure the combination of cooling the attic and adding the garage to the AC should cancel each other out in terms of additional load on the house AC.
If you look carefully above the drill press, you will see a handle and long threaded pole. This is used to raise and lower the drill to the work being performed. This contraption also extends reach of the drill so where will be less free hand drilling.
If you can't bring mohamned to the drill, bring the drill to mohammed!
Drill Press
Drill Press
Workbench
Workbench
20 Tons Baby!!
20 Tons Baby!!
