Our RV-10 Adventure
RV-10
Horiz Stabilizer
4-15-2007
Assembled HS After Primer
Put the HS back together in anticipation of riveting. Got the nose ribs in, dropped in the front spar and put in the blind rivets to the nose ribs.
Assemby after primer is easy
Drop in the spar
Almost done; can use the squeezer on the spar!
RV-10 Home
Elevator
Horiz Stabilizer
Priming
Research/Ordering
Tail Cone
Vertical Stabilizer
