Brief Description: Finished Priming VS, Rudder and HS Spars
I finally got the motivation to tackle the priming job. After Alodine yesterday, I sprayed on the AKZO epoxy primer. I used a hopper type HVLP spray gun from Harbor Freight. It worked great and the clean-up was not too bad. I finally started riveting parts together. It seems like I'm off and running. I guess the fear of the unknown was worse than actually priming the parts.
