Photo 1: Here I am connecting the pin connectors to the wires, and installing them into the connector body shell.Photo 2: This is the finished panel with the cannon plug connectors on the right side.Photo 3: This is the plug strip I will install at the rear of the fuselage to mate up the connections in the rear to the main harness bundle that will connect to the instrument panel.
