Photo 1 shows the clasp connectors I installed on the engine wiring harness. The blade connectors that came with the engine are notorious for comming apart, so I replaced them with these clasp type ends.Photo 2 shows the clasp connector on the engine ground [brown] wire with the heat shrink tubing installed.Photo 3 is the starter switch electical bus line, setting behind the starter solinoid.
Clasp connectors installed on engine wiring harness.
