Photo 1 shows the back side of the left side buss panel. It has the Hobbs Meter, switches & circuit breakers installed.Photo 2 is the trail fit of the completed side panel in the cockpit. The primary buss breaker switch, fuel pump switch, circuit breakers and Hobbs Meter are on this panel.Photo 3 shows the final installation of the left side buss panel, and the trail fit of the right side buss panel installation. The Avionics buss, head set kacks and oil level warning light will be installed on this panel.
Back side of buss panel
Trial fit of the buss panel left side of cockpit
Final fit of left buss panel, trial fit of right side buss panel
